Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy monza trans swap
Old 09-09-2007, 10:01 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by dcoates18481
i am looking to put a glide or th-350 in a monza i'm building with the stock rear( for now )..
my question is, can i take the tailshaft cover from the original trans ( i think a th 200 ) and put it on the glide or th-350.
the reason i want to do this is the original housing has the provision for the torque arm.
unless someone knows a way i can mount the torque arm differently?
thanks
A t-200 does not have a removable tail housing.
the OEM trans in the Monza may be a t-350 trans. That tail housing will NOT fit a glide.
photo of a Monza t-350 trans. GM left off one bolt hole location because of the lack of space at the firewall.
