Chevy motor into Oldsmobile body - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2013, 08:48 AM
whojohnjones's Avatar
Would I need to weld the Chevrolet frame mounts in the Oldsmobile body or could I just bolt them in?
Old 05-15-2013, 09:08 AM
Wiki Edits: 31
What olds? Anything from like '65 going forward till the '80's, you can just swap the engine stands and some wiring and you can put any GM engine in you want provided it was available in that chassis
Old 05-15-2013, 09:22 AM
1984 Delta 88
Old 05-15-2013, 09:45 AM
RWENUTS's Avatar
It should bolt in. But the tranny won't bolt up if you're using the stock one.
Old 05-15-2013, 09:47 AM
Originally Posted by whojohnjones View Post
1984 Delta 88
Apparently not everyone remembers the big Chevy motor in Olds Delta 88 lawsuit...
Old 05-15-2013, 09:48 AM
It's got the 200 tranny.. I have a 1983 electra with a Chevrolet engine but the mounts are welded in I don't know y they were welded in though
Old 05-15-2013, 12:36 PM
Because whoever swapped the Chebby motor into the Buick had no clue that the chassis is the same as a Caprice and has all the bolt holes for the motor mounts for pretty much any GM RWD engine.
Old 05-16-2013, 04:09 PM
1983 was five years after GM changed the "Small block Chevy" into the "GM Corporate small block" and put them in everything including that Buick. It came from the factory with the "GM corporate small block".
Old 05-16-2013, 04:11 PM
And the "GM corporate small block" lawsuit across the whole GM lines in Pontiacs, Buicks, Old's, they all got the small block that was once a Chevy in 1978 (or was it 77?) and the poop hit the fan!
Old 05-17-2013, 09:46 AM
Actually, no. Most of the non-Chevy B/C-body cars got the Olds 307 in the 1980s. Heck, my 86 Caprice wagon even came with a factory-installed Olds 307. The fact remains that the frame already has the bolt holes to bolt up motor mounts for every GM small block ever made (even Caddy motors since the Fleetwood used a version of this chassis with the 425 and 368 motors as well as the 4.1/4.5/4.9 liter family). Whoever welded the SBC mounts into that Buford was too lazy to take the time to do it right.
Old 05-17-2013, 11:49 AM
You are right, I know they used the SBC in the Regals, but in the Electras I think they did use the Olds.
Old 05-17-2013, 12:21 PM
Banned
iirc the regal got the 307 olds(just like the gutlass and g/p) /3.8 v6(buick) n/a or turbo
th malbu and monty got the 305 chevy because they got the 229cid chevy v6 ( and then later in life got the 4.3ltr v6)and not all 2004r's have the dual bolt pattern bell housing
Old 05-17-2013, 02:28 PM
While that info is correct, none of it applies to this thread, which is about a Delta 88. That's why I keep talking about the B/C/D-body cars and not the G-body cars.
Old 05-17-2013, 03:00 PM
Banned
yup but the b bodys all have the holes for any g.m. engine(v6/v8) at the time.
including the 4100 catty
229/231/262/267/305/307/350/260 diesel/350 diesel/4100
Old 05-18-2013, 02:23 PM
Kinda what I said back in post #10...
learning how to identify the size of an oldsmobile v8 motor sean 1968 olds Introduce Yourself 2 01-01-2011 06:52 AM
oldsmobile 330 heads on an oldsmobile 305 JohnnyBoy Engine 8 08-11-2009 11:37 AM
Chevy Quadrajet on oldsmobile engine? glamaina Engine 9 07-28-2008 04:50 AM
Do GM (Buick,Cadillac,Pontiac,Chevy,Oldsmobile) V8's sound different between them ? Calderone Engine 4 02-03-2008 03:55 PM
What is a 455 Oldsmobile "Rocket" Motor? slider in wa Engine 2 03-19-2004 10:59 PM
