chevy motor,pontiac trans fit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2010, 07:00 AM
chevy bb 572's Avatar
CHEVY BIG BLOCK 572
Last journal entry: sum rides i got
does anyone know if a 70 pontiac transmission will bolt to a 76 chevy 350?
Old 09-28-2010, 07:25 AM
only with an adapter
Old 09-28-2010, 04:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Manual or auto ?
Cole
Old 09-29-2010, 10:22 PM
KA67_72's Avatar
If I remember right, only two bolts and the dowels line up. I have a BOP th400 behind a sbc in my Jag. The Chevy th400 welded itself together and I had a built BOP 400 laying around. I welded two 3/8" thick aluminum tabs above the dowels and a plate between the ears up top. So I have five instead of six bolts. I haven't had any trouble so far. Adapters are less than $100 if you don't have a TIG or torch. If you have a bad Chevy trans you could swap the good internals into it also.
Kevin
Old 09-29-2010, 11:01 PM
Last journal entry: Frame pics
Speedway motors sells the adapter plate for $40 cheapest I've found so far, I was considering this swap myself. I had a 400 pontiac I was going to put behind my 350 til I realized how much hp they sucked.
454 chevy in 79 trans am, possible? Trans Am Benny Engine 9 12-31-2011 12:06 PM
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 11:51 AM
Trans Question on my 2001 Chevy Silverado albino2_wolf Transmission - Rearend 0 09-16-2007 08:30 PM
HOW TO MAKE 700R ELECTRONIC TRANS WORK IN 59 Chevy pick up hexx Transmission - Rearend 4 02-11-2007 02:31 PM
Trans Question on my 2001 Chevy Silverado onebadmerc Transmission - Rearend 2 01-04-2004 04:04 PM
