Here's a silly question - why not just use the M/C that comes from the same type of car as the brakes? Then there's no question that it works. Failing that, you should match the piston diameter in the M/C with the one that was used with those brakes originally.
I will second Joe P's answer. The most important aspect of master cylinder choice is the bore size relationship to the calipers, following that , there are springs and valves intergrated into some master cylinders that govern pressure output, front /rear bias and timing and residual pressure.
If he can't make sure that his new master cylinder will have the same characteristics in operation as the OEM part, then he should not try to cheap out by buying a MC intended for another type of brake system. (you did say his first concern was cost) I've never worked on a bmw, so I have no idea what they integrate into the MC...but I would do some research to find out before I just went ahead swapping parts. I'll add this, a 1/2 ton chevy truck MC is probably way too big for the small piston calipers that are probably on that bmw. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Power Steering Or Not? 35 Chevy Master | marks914 | Suspension - Brakes - Steering | 8 | 11-26-2007 11:02 AM |
| power steering for 1958 chevy | fast454camaro | Suspension - Brakes - Steering | 14 | 02-11-2007 10:33 AM |
| Looking for 1985 chevy k-10 wiring diagram for power doors and windows | Jobo62 | Electrical | 7 | 11-20-2006 05:45 AM |
| Power brakes on 1960-1966 Chevy C-10 | ss crazy | Suspension - Brakes - Steering | 1 | 04-09-2003 04:14 PM |
| power steering 56 chevy | chas | Suspension - Brakes - Steering | 1 | 05-08-2002 03:36 PM |
