It is supposed to be inserted all the way up to the bulge in the pipe. There is a tool for this, but I have used an appropriately sized open end wrench and a hammer to install them before.
Vince |
Lee |
Is it going in straight? It's sometimes hard to tell because the metal will conform to a certain degree allowing it to go in until it just stops. Pull the pickup back out and look for a "step" looking toolmark going halfway around the tube. If there is, this is a sure indicator of going in crooked. I learned that that it helps to rotate the wrench side to side while tapping it to help keep the tube centered.
And wear a glove it smart's in your hand. |
sometimes there can be a problem mixing and matching pickup's with oil pumps, are you using a moroso pickup with a meiling pump (or something of the nature)?
I was considering "honing" the oil pump housing and removing .002" or so to make it a bit easier going in - I was going to weld it on anyway so I'm not worried about it falling out. If I remove material though it means I have to take apart the pump and clean it out afterwards. |
I'll just have to oil it up a bit more and wack it harder and make sure it's straight. If I had something better then a wrench to fit around that collar to wack on that would help. Lee |
Put the pickup in the freezer overnight.......with it cold, it will shrink a bit and with the pump at room temp, it should go in easier.
Ontario Rodders |
it occured to me...........If I have to beat on this thing with a hammer and a special tool to press it into the pump housing - why would it fall off?
Do I really need to weld or braze the thing on there? Where's it going? Something that would take that much force and pounding to get it on would not fall off in my opinoin - especially if nothing is pulling on it. Maybe I would be better off just leaving it as it. Your thoughts? |
I have never welded one yet nor had one fall off in 20 years of dirt tracking.And I never could figure out how you could get a good weld between a cast iron pump and steel tube. Brazing might make sense but I doubt it is really needed.I notice the factory doesn,t bother with it.
That settles it. If I can get it fully seated with that installation tool I'll just leave it alone. |
| oil change- step by step instructions for women and men | Fireball | Hotrodders' Lounge | 38 | 08-30-2008 07:39 AM |
| 53 chevy pickup question | 53deluxe | General Rodding Tech | 4 | 11-29-2007 09:27 AM |
| Valce cover Oil leak problem / PCV system question | hotrodf1 | Engine | 7 | 05-01-2007 02:44 PM |
| Quickie Oil Pickup Question | MI2600 | Engine | 2 | 07-17-2006 06:38 PM |
| Should I change my oil? | 48Man | Engine | 2 | 01-29-2003 07:28 AM |
