chevy overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2012, 05:36 PM
chevy overdrive
hello , what year and type overdrive would be the easiest to install in a non overdrive car, by this i mean mainly hooking up the electrics. thanks
Old 01-23-2012, 09:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Not near enough information on your plans for which trans is easier to install.
200-4r or 700r4 trans need minimum electric hook up.
No electric needed if you go with a non lock up converter on the trans. Trans needs modifications for non lock up.
1990 chevy k1500 tranny stopd going into overdrive? gofastz Transmission - Rearend 2 09-06-2011 08:36 AM
Chevy Nova 3 speed overdrive strummin67 Transmission - Rearend 7 11-30-2006 01:59 AM
Chevy overdrive 1981monte Transmission - Rearend 12 07-31-2004 09:37 AM
overdrive trans for bb chevy truck Pycho baldy Transmission - Rearend 5 12-04-2003 06:24 PM
need a overdrive tranny chevy 73monte Transmission - Rearend 2 11-29-2003 02:30 AM
