chevy pick up or dodge van/pu straight front axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2008, 07:07 PM
ddpecka348's Avatar
this would be under a gasser. i would lik to know what the length of the springs for them? and what is the length of the axle from eye to eye? and what kind of disc brakes would fit on to these? thanks.
Old 02-23-2008, 07:27 PM
willys36@aol.com's Avatar
Wiki Edits: 21
If you are thinking a Willys gasser, those axles are too big all round. Too thick, too long, too everything. Go for a stock Willys suspension or Speedway tubular axle setup instead.
Old 02-23-2008, 07:43 PM
AntnyL's Avatar
I justed checked a Chevy truck straight axle and springs from my scrap pile. The kingpin eye-to-eye dimension is 54 inches. The spring perches are 34 inches on center. The spring eyes are 43 inches on center.
I hope this helps.
Old 02-23-2008, 10:02 PM
ddpecka348's Avatar
gasser
this is guna b under my 1937 plymouth coupe gasser in progress. but what bout a 53-56 ford pick up?
Disk Brake Conversion for 1947 Dodge 1/2 ton pickup front axle leonard egan Suspension - Brakes - Steering 4 01-21-2011 06:17 PM
split straight front axle with rack and pinion dmcurry22 Suspension - Brakes - Steering 15 01-08-2009 11:15 PM
'47-'54 front axle flip!? suedespade Suspension - Brakes - Steering 3 04-13-2007 08:00 PM
Chevy II Front Brake Conversion problem Trevor Horn Suspension - Brakes - Steering 5 04-05-2007 08:10 PM
Front straight axle- drag brainsboy Suspension - Brakes - Steering 3 02-08-2005 12:17 PM
