chevy pickup rear axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2009, 12:41 PM
Ratdoggy's Avatar
Hammer torch chisel...
Last journal entry: Got the wheels on
We have a '91 Chevy 3500 stake body truck at work. It lost a rear wheel and damaged the axle housing end and the hub. We've been kicking around the idea of replacing the dually with a single wheel pick-up axle ( we don't carry a lot of weight and it's probably cheaper) Does anyone know what would fit as a bolt on
Thanks
Mike
Old 08-28-2009, 01:16 PM
fast68's Avatar
likes chevy trucks & boobies
check rear spring pack distance from each other as on the old body style the distance was different between 1 ton and 1/2-3/4 tons
used to be 42.5" distance on non- 1 tons
and 40" on 1 tons
but in 88 they seemed to have widened
plus on duallies it has to have packs closer to each other to clear the extra set of wheels
need a tape measure to answer your own Q on 88-up
there were also chassis cabs with SRW
not all chassis cabs were DRW
just liek there are DRW picups as well
you could get any configuration you wanted, when available
there were some interesting ones built and sold special order as well.
even some oddballs like dually burbs for fire/rescue service were built and sold
Old 08-28-2009, 01:17 PM
A 14 bolt is what you want. If it isn't 4x4 then you can get any gear you need. A good source for them is military surplus. you can usually get them with 4.56 gears and detroit locker for a song.
Old 08-28-2009, 01:47 PM
Ratdoggy's Avatar
I''m guessing that if we got the axle from a junkyard we could get the spring hangers and springs too. I should have made myself clear before. We just want easy and cheap. Do all the trucks use the same spring hangers?
61 chevy 1/2 ton rear axle goneinsixty Transmission - Rearend 1 02-18-2009 08:57 PM
what trans/rear axle for my 40 Chevy Coupe? RoadHouse Tim Transmission - Rearend 23 12-22-2008 03:22 AM
rear suspension 40 chevy pickup 71corvette Hotrodding Basics 8 12-10-2008 10:34 PM
57 Chevy pickup rear suspension 57halfton Suspension - Brakes - Steering 14 01-16-2007 06:29 PM
1955 Chevy Pick Up, Wheel rear spacing? Alf Transmission - Rearend 1 09-19-2002 07:02 PM
