BUICK
Cyl. Engine Bore Years Comp. Ratio NOTES: Part No. Sizes Rings O.E. Assy. No. O.E. Casting No. Head Shape V8 307 5.0 L 3.800(IN) 96.5(MM) OLDSMOBILE ENGINE 1980-84 7.9 2.70" dia. head recess .107" deep. APPROXIMATE HEAD VOLUME=9cc Comp. Ht. 1.595 Pin Dia..9805 offset 1636 Std. .020 .030 .040 .060 2-5/64 1-3/16 22506658 22504964 V8 307 5.0 L 3.800(IN) 96.5(MM) OLDSMOBILE ENGINE 1985-90 8.0 Recessed head .270" deep. Broken sets factory only. APPROXIMATE HEAD VOLUME=15.5cc Comp. Ht. 1.605 Pin Dia..9805 Offset 1639LR Std. .020 .030 .040 .060 2-5/64 1-3/16 22527480(R) 22527479(L) 22527033 V8 340 5.6 L 3.750(IN) 95.25(MM) BUICK ENGINE 1966-67 8.4 3.06" dia. head recess .23" deep. APPROXIMATE HEAD VOLUME=26cc Comp. Ht. 1.835 Pin Dia..9398 Offset 1724 Std. .020 .030 .040 .060 2-5/64 1-3/16 1395184 1374154 V8 350 5.7 L 3.800(IN) 96.52(MM) BUICK ENGINE 1968-81 8.7 8.6 8.0 8.4 3.05" dia. head recess .215" deep. APPROXIMATE HEAD VOLUME=24.5cc Comp. Ht. 1.805 Pin Dia..9398 Offset 1731 Std. .020 .030 .040 .060 2-5/64 1-3/16 1394208 1394558 1249538 22501423 25527178 1382128 1231899 1247241 1255672 25522904 25519456 V8 350 5.7 L 3.800(IN) 96.5(MM) BUICK ENGINE 1968-81 8.5 Hypereutectic, destroked .020". 3.05" dia. head recess .235" deep. APPROXIMATE HEAD VOLUME=25.5cc Comp. Ht. 1.805 Pin Dia..9398 Offset H1740 Std. .020 .030 .040 .060 2-5/64 1-3/16 1249538 1394558 25501423 1394208 25527178 1247241 1231899 1255672 1382128 25522904 25519456 V8 350 5.7 L 4.000(IN) 101.6(MM) CHEVY ENGINE 1977-79 8.1 VIN L. 3.16" dia. head recess .08" deep 4 valve reliefs. Use 1986 & earlier rings only. APPROXIMATE HEAD VOLUME=13cc Comp. Ht. 1.540 Pin Dia..9273 Offset 1470 Std. .020 .030 .040 .060 .080 2-5/64 1-3/16 6271097 3991488 10159424 6271096 3991476 10128212 V8 350 5.7 L 4.000(IN) 101.6(MM) CHEVY ENGINE 1977-79 7.9 Hypereutectic, destroked .020". 3.14" dia. head recess .07" deep with 4 valve reliefs. Use 1986 & earlier rings. NOT INTENDED FOR RACE APPLICATIONS. APPROXIMATE HEAD VOLUME=12cc Comp. Ht. 1.560 Pin Dia..9273 Offset H1476 Std. .020 .030 .040 .060 2-5/64 1-3/16 3991488 6271097 10159424 3991476 6271096 10128212 V8 350 5.7 L 4.000(IN) 101.6(MM) CHEVY ENGINE 1990-95 9.3 Hypereutectic flat head with 4 valve reliefs. Piston destroked .020". APPROXIMATE HEAD VOLUME=7cc Comp. Ht. 1.540 Pin Dia..9273 Offset H1489* Std. .020 .030 .040 .060 1-2.0mm 1-1.5mm 1-4.0mm 10159436 10128452 T0Z2110V13 10128454 * NEW PISTON, AVAILABLE NOW **NEW PISTON, CHECK FOR AVAILABILITY Page 15 -------------------------------------------------------------------------------- Previous Page / Table of Contents / Next Page |
thanks 4onthefloor 2
thanks for the knoledge. Now i am thinking of going with eagle rods that are rated up to 500 horse, and kieth black pistons. along with this I want to go with the edelbrock perfromer RPM package. you know the heads the cam, intake and so on. Does this sound like a good combo, or does somebody have a better combo for me that might even be cheaper?
| 383 stroker chevy | brainsboy | Engine | 2 | 04-09-2004 09:10 AM |
| Small Chevy car wheel to fit Chevy Truck | musky2 | Transmission - Rearend | 4 | 03-16-2004 08:12 AM |
| I Need Help With 31/32? Chevy | walt | Hotrodders' Lounge | 9 | 03-02-2004 06:42 AM |
| BB chevy pistons | Gassman | Engine | 2 | 01-19-2003 05:22 PM |
| need opinions on pistons | crshrmn3 | Engine | 5 | 01-11-2003 06:29 PM |
