Chevy power gearbox - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2007, 03:59 PM
play with fire
Chevy power gearbox
I have an '85 power steering gearbox on my '66 GMC. It's been so long since I've messed with it, I've forgotten which is the pressure and return ports. Does anyone know for sure? Is the pressure port closest to the rag joint, or the other way around?
Old 11-14-2007, 06:18 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
The largest fitting is the pressure flex hose. The metal return pipe is the smaller fitting.
The newer box you have requires the newer O-ring fittings. The older ones used a common flared fitting.
chevy 383 power? johnsquicks10 Engine 5 02-06-2007 03:49 PM
Looking for 1985 chevy k-10 wiring diagram for power doors and windows Jobo62 Electrical 7 11-20-2006 06:45 AM
605 power steering conversion for a 56 chevy slickstick56 Suspension - Brakes - Steering 5 06-21-2006 06:10 AM
Jaguar and Chevy power steering systems Neophyte Suspension - Brakes - Steering 4 08-27-2004 09:55 AM
disk brakes and power steering for 59' chevy marley3 Suspension - Brakes - Steering 3 08-15-2003 01:11 AM
