chevy power steering pump pulley - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2010, 08:39 PM
65ELCMO's Avatar
Is the power steering pump pulley for a short and long water pump the same on a small block chevy?
Old 06-04-2010, 03:55 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I am almost %100 that there is a difference in the two, And i know that there is a difference in the brackets on the power steering pump. I do know without a doubt there is a difference in the water pump and the crank pulleys for a short and long pump though. JMO But i don't run power steering.
Cole
Old 06-04-2010, 06:37 PM
Found an interesting pic comparing early/late model P/S pumps. Can't say if the pulleys are the same...they look identical with maybe a slight difference. Can't tell if the shaft diameters are the same though.
http://www.chevyhiperformance.com/te.../photo_06.html
Old 06-04-2010, 07:19 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
The P.S. pump is on a different pulley on most cars.
Luv the smell of NITRO in the morning.
Is this a Saginaw power steering pump? johnnnz Suspension - Brakes - Steering 2 04-23-2008 03:07 PM
power steering pump mounting help cro77 General Rodding Tech 1 04-08-2007 07:30 PM
power steering pump question 46 chevy pickup Suspension - Brakes - Steering 7 08-25-2006 07:05 PM
Jaguar and Chevy power steering systems Neophyte Suspension - Brakes - Steering 4 08-27-2004 08:55 AM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
