Chevy Ram Jet 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2010, 08:53 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Chevy Ram Jet 350
Has anyone added the Ram Jet FI unit to a previously carbed 350 or a ZZ 4 350?
How do these units compare with the aftermarket FI in cost and performance?
What needs to be changed besides the obvious, Dist and fule pump, does it need a return fule line?
Old 06-26-2010, 02:59 AM
454headache's Avatar
I'm fairly sure ALL F.I. system require a return line due to the high pressure requirements.
A cheap and real trick alternative might be a OEM dual TBI setup with a stand alone engine management system.
Old 07-06-2010, 09:17 AM
solidaxel's Avatar
>>>>>>>>>>>>>>>>> T T T <<<<<<<<<<<<<<
Old 07-06-2010, 11:40 AM
The Ramjet intake manifold wont fit a ZZ4 350 or conventional 12 intake bolt 350 due to the Ramjet intake using a Vortec 8 intake bolt patter with raised intake ports.
Yes it requires a return line. The Ramjet intake will fit on a 1996+ L30/L31 Vortec 305/350 engine, the ZZ430 430hp crate, the ZZ383 425 hp crate as well as teh 350HO crate(which is just a Vortec 350 with the roller cam and lifters ripped out and replaced by a flat tappet system. Never buy a 350HO over a stock 1996-2002 L31 replacement engine.
peace
Hog
Old 07-07-2010, 08:04 AM
solidaxel's Avatar
Thanks for the reply,
I guess I will have to look elseware for a inexpensive fule injection for my ZZ-4
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
