chevy rear frame
I just got a chevy 1988 s-10 and i am planning to tube it out. I was just wondering what would be some good set ups and how to do it? I have looked at some of the stuff in summit and seen kindove how it looks but i just need some help on what to get like the four link set up of just buy all the stuff seperate and put it together myself? I can use any help i can get so thank you.
what is the intended use for truck??......check out www.swracecars.com they can get you some good ideas and/or parts. they already have a rear frame kit for your truck.
Tubbing an S-10
I built my pro street S-10 at home in my garage.I am running leaf springs with lakewood slapper bars. I cut the frame off between the cab and the front bed mount,then I narrowed the rear frame section about 10" I just sectioned the stock crossmembers and welded them back together. I connected the narrowed rear section to the stock front section with 2x4 steel tube. I kicked the rear section up about 4" at the juncture by angling the tubing up and in.I had to "channel" or cut the floor loose in the whole bed and drop the bed to match up with the cab.this let the truck sit real low and still have suspension travel.I am running 31x18.5 tires on 15x14 centerline wheels.I will try to get pictures,but we have 12" of snow right now and the truck is parked. This truck is built as a daily driver,built at home and built on a budget.
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| 55 Chevy pick on S-10 frame | Lead foot | Hotrodders' Lounge | 11 | 07-24-2009 07:56 AM |
| Problem/Correct length rear for 40 Chevy | 1940chevy | Transmission - Rearend | 6 | 12-09-2005 11:40 AM |
| Chevy rear end swap | Truplayainfla | Introduce Yourself | 1 | 10-23-2004 11:07 PM |
| 1955 Chevy Pick Up, Wheel rear spacing? | Alf | Transmission - Rearend | 1 | 09-19-2002 07:02 PM |
