-   -   chevy rearend housing ID (http://www.hotrodders.com/forum/chevy-rearend-housing-id-216247.html)
iarednek 03-07-2012 06:20 PM
I am tring to I.D. a couple of chevelle rearends and housings in a camaro posi unit and housing. I am trying to put the camaro posi unit in a chevelle housing. I found a web site that says there are the numbers 410408 as a series 3 or 410409 as a series 2, I can not find these numbers anywhere on the rearend unit or the housing. One website said to measure the distance between bottom bolt hole and the next hole either left or right, 3 1/4
is a 7.5 --3 1/2 is a 8.5. All 3 of housing the measure 3 1/4. I am trying to put the posi unit in a 65 GTO. I'm usuing the chevelle housing becasue chevy parts are easier to find than Pontiac housings. Thanks for any information you have.
SSedan64 03-08-2012 12:26 AM
Those numbers will be on the end of the Posi Carrier, also possibly Large 8's or Large 9's.
Info/Pics >> http://www.buickperformanceclub.com/posi.htm
http://www.buickperformanceclub.com/85rear.htm
7.5" vs 8.5" Rear Housing ID >> http://dyeager535.topcities.com/diffid.html
Other 10-Bolt Info >> http://www.oldsmobility.com/old/10bolt-tech.htm
iarednek 03-08-2012 04:09 AM
rear end ID
Your information was very helpful, Thank you very much
