chevy rearend housing ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 05:20 PM
37 ford
I am tring to I.D. a couple of chevelle rearends and housings in a camaro posi unit and housing. I am trying to put the camaro posi unit in a chevelle housing. I found a web site that says there are the numbers 410408 as a series 3 or 410409 as a series 2, I can not find these numbers anywhere on the rearend unit or the housing. One website said to measure the distance between bottom bolt hole and the next hole either left or right, 3 1/4
is a 7.5 --3 1/2 is a 8.5. All 3 of housing the measure 3 1/4. I am trying to put the posi unit in a 65 GTO. I'm usuing the chevelle housing becasue chevy parts are easier to find than Pontiac housings. Thanks for any information you have.
Old 03-07-2012, 11:26 PM
SSedan64's Avatar
Those numbers will be on the end of the Posi Carrier, also possibly Large 8's or Large 9's.
Info/Pics >> http://www.buickperformanceclub.com/posi.htm
http://www.buickperformanceclub.com/85rear.htm
7.5" vs 8.5" Rear Housing ID >> http://dyeager535.topcities.com/diffid.html
Other 10-Bolt Info >> http://www.oldsmobility.com/old/10bolt-tech.htm
Old 03-08-2012, 03:09 AM
37 ford
rear end ID
Your information was very helpful, Thank you very much
8.2 rearend housing or not? compton316 Transmission - Rearend 3 04-14-2009 08:55 PM
Need Help: Chevy starter housing ChevyBass Engine 9 03-30-2008 07:51 PM
Welding on Rearend Housing Thirty Seven Ply General Rodding Tech 5 04-05-2007 09:35 PM
How to check rearend housing for warpage? shockers69 Transmission - Rearend 1 07-12-2004 11:11 PM
Welding on rearend housing Dep ME Transmission - Rearend 3 05-16-2004 08:29 AM
