Chevy rearend off center, offset leafsprings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2011, 12:41 PM
Popadopalis's Avatar
Last journal entry: Bare Bones
Car: 1953 Pontiac Cheiftain (Canadian)
Issue: Tires sitting to far foward in rear fenders (common issue with old chevys)
Fix: Buy offset Leaf springs
Part: Found part on Eklers 21-261 for 55-57 chevys
Question: Will the 1955-57 offset leafsprings fit a 1953 Pontiac or for that matter a 1954 chevy? When I called Ecklers she simply state no but also said they didn't sell offset springs for any earlier models than 1955.
Or does anyone have a better idea to back the rearend about an inch in order to put bigger wheels on.
Thanks for any help!!
Old 09-13-2011, 01:29 PM
I have used a offset block before. Go here
http://www.chassisengineeringinc.com/page27.html
Look at the bottom of the page and find part # AR-2070
I made mine and did not buy theirs ...
Easy to make ... BUT their catalog photo makes it easier for me to show you ... the solution.
DEUCE ... Moderator
Old 09-13-2011, 04:35 PM
lowering blocks
That's a great idea, I've looked in to it before, but I don't want to lower the back so I guess I could restack the leafsprings to raise it and then install the lowering blocks...hmmmm... I really want to know if the 55-57 offset leafspring will fit the 54 chevy chassis mounts because I'd rather get new leaf springs.
Thanks for the help!
Old 09-13-2011, 08:36 PM
The 55 spring won't fit, too long. Posie's make a spring that will fit with a centered center bolt. Part number is 203A
Old 09-13-2011, 09:45 PM
Sixshooter45's Avatar
I went with the Chassis Engineering spring kit on my '53 Chevy. Worked like a charm, I would recommend it.
Old 09-13-2011, 10:00 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
We're talking about rear leaf springs, right?
I don't know about other cities, but there is a spring shop in Calgary called Standens. They will build leaf springs to your specifications.
Try *your* local spring shop?
Old 09-14-2011, 09:37 AM
S10xGN's Avatar
Gotta love a turbo!
Couldn't you just re-drill the spring bolt (mounting) holes in the spring perches and U-bolt plates?
Russ
Old 09-17-2011, 03:45 PM
Thanks for all the replies. I'm going to go with making new leafsprings from the local shop. I don't think redrilling them is the correct way to go but would probably work in the short term, I believe the springs are rated to the original center point.
Old 09-17-2011, 09:12 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Then just redrill the bottom leaf and re stack the rest in the same hole
Old 09-18-2011, 12:10 PM
S10xGN's Avatar
Gotta love a turbo!
Obviously, you've never tried this. In my younger days, I went through a half dozen bits on just one of the leafs before giving up. After a bit more experience, I came to realize that leaf springs (like any other spring) are highly stressed and not very forgiving to having stress risers induced. Leave the springs alone and find another solution...
Russ
Old 09-18-2011, 06:01 PM
solidaxel's Avatar
Russ
You are right, I took it to the local spring shop and he drilled it for me and removed three leafs
9" Ford truck rearend w/ 4" offset in A model Roy King Transmission - Rearend 3 03-11-2010 09:37 AM
rearend is offset runn141 Transmission - Rearend 1 02-16-2009 11:57 PM
Offset rearend and pinion angle murrsue Transmission - Rearend 5 05-19-2007 06:51 PM
Rim offset for classic Chevy truck?? DV8 General Rodding Tech 6 06-15-2006 10:08 PM
Hookin up with leafsprings? BBC T/A Suspension - Brakes - Steering 13 01-26-2006 11:35 AM
