Chevy rearends.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2006, 11:07 AM
SecGenLvr's Avatar
Chevy rearends....
I have a 78 Camaro that I am rodding out, and I have a SB 400 I am putting in it. I haven't completely decided what I will do with it, but I am hoping to have around 350 HP running out of it. But I am looking into a richmand 5 speed, and want to know what options I had, and if there aren't many, what would be the best way to go for a richmand 5 speed and a rear end (best combo).
I want to have a good street/strip car nothing too fancy and I don't want to lose too much highway speed. Thanks for your help in advance...
John
Old 02-06-2006, 12:15 PM
larryblack's Avatar
Certified Lead Foot
You want to look at tire size, diameter, along with your rear gear and 5th gear ratio. Plan on having a rpm that falls into the cruise range of your cam. If your 5 speed is 1:1 5th go with 3.08 to 3.42 for good hwy cruising. If you have a OD 5th you can go to 3.55 or 3.73 and get good hwy rpm. Tire size will probably be between 26 and 28 inches diameter.
Go to www.lightlineofla.com and on the lower left there is a link to gear/tire/rpm formulas. It is for 4x4's but just put 1 into the transfer case value and you can see tranny gear, rear gear and tire diameter's effects on rpm or any way you want to go.
There is a formula to convert your tire size, 235-60-15 to diameter.
Old 02-06-2006, 03:16 PM
SecGenLvr's Avatar
I was looking at a richmond 5 speed with a 3.28 first gear and my differential was going to be a 2.41.... what brands and types do you recomend me look for...
Old 02-07-2006, 01:35 AM
Ozz1967's Avatar
Air Force Guy
If you have the stock rear end, you won't have to make any changes except the gearing. With the 5-speed and less than 1:1 5th gear, I'd go with the 3.73's. Otherwise with a 1:1 5th, I would go with a 3.42. On 255 50 R15's (On my 67 Camaro) I was running 3000rpm at 70mph and a 1:1 4th gear on my Muncie and 3.42 rear gears.
Old 02-07-2006, 07:20 AM
SecGenLvr's Avatar
Well I was thinking I wanted posi or a limited slip system...
Old 02-07-2006, 01:00 PM
Ozz1967's Avatar
Air Force Guy
I'm pretty sure a 78 Camaro has limited slip. Hmm, if not, it's a simple thing, just fine one from a Z28 or even go aftermarket and buy one from Eaton. Another option, is to get a rear end out of an Earlier first gen. They should match up pretty well.
Old 02-08-2006, 11:01 PM
Richmond 5-speeds have a 1:1 5th gear, with no overdrive. Last I heard, they were available with an extra-wide-ratio gearset, with something like a 4.08:1 low gear. To me, this would be best for use with a 2.41 rear end. Using a 3.28 low gear with a 2.41 rear will have you burning up the clutch just trying to get the car moving from a dead stop, and moving very slowly from that dead stop.
Multiply your rear end ratio by the low-gear ratio. Anything over 9 or 9.5 will be comfortable to drive with typical car-diameter tires. 2.41 x 3.28 = 7.9, which will be a pain. 2.41 x 4.08 = 9.8, which would be nice, and you'd still have that overdrive-like 2.41 gear for highway cruising.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? mistermuscles Transmission - Rearend 0 07-18-2004 05:40 PM
chevy 10 bolt rearends torgue specs fuman Transmission - Rearend 0 12-24-2002 10:26 AM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
