Chevy Rearends - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2006, 11:50 AM
Chevy Rearends
Anyone now the difference between a series 2,3 and 4 carrier housing? Also dose anyone know wear I can get an open housing.
Old 10-02-2006, 11:48 PM
That refers to the different ranges of gear ratios used with each different carrier. Lower series number carriers are used with lower ratios because lower ratios have larger (in diameter) pinion gears, and that means the ring gear (and the ring gear flange) has to be farther to the left of the pinion centerline.
The ratio range of each carrier series varies with different rear end designs. In other words, just because one changes between 2.56 and 2.73 doesn't mean they all do. They don't, generally. Some don't even have a 4-series carrier.
Old 10-08-2006, 10:33 AM
LordMaximo's Avatar
Last journal entry: Painting
Correct and it really is a crash to most who had grand illusions of just a simple upgrade to their ride. GM and Chevy had specific standards for weight ratio on their types of rides. For example, some camaroes came with a 10 bolt and others came with the 12 bolt. This is because of the engine and class design of this model when released. Thus, your transmissions and rear ends where matched tothe HP rating of the engine offered in each series released. Three choices of camaroes, three drive line packages offered.
Some had the momas' ride, got it as a first drive in school. Thought it could be beefed up in the engine, forgot about the final drive. They go to upgrade, so they thought, the rear end, only to find there is three options in the upgrade of the third member, what a bummer! These are the ideo-thoughts of the engineering departments. They do this to force the consumer into purchasing the upgrade at the show room floor. Ching-ching! Sorry......
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 09:01 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 11:32 PM
Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? mistermuscles Transmission - Rearend 0 07-18-2004 06:40 PM
chevy 10 bolt rearends torgue specs fuman Transmission - Rearend 0 12-24-2002 11:26 AM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 04:04 AM
