chevy rims on a buick - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2006, 06:58 PM
75sprintguy's Avatar
Last journal entry: a good used 350 we installed
quick question can you guys tell me if chevy rally rims will fit on a old 72 buick skylark got to pull it home and all the tires are rotted and flat i have some chevy rims laying around i was going to use them if they fit thanks jon
Old 01-19-2006, 07:10 PM
Yes chevy rally rims fit a 72 skylark
Old 01-19-2006, 07:34 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Back then a Skylark was considered a Small car the big ones like the 225 Electra and wagons typically had a bigger spaced lug pattern .
Same thing across the divisions Pontiac Oldsmobile & I do believe Chevy ad the "big wheels" too
"SlowRide66"
"Illegitimis non carborundum"
Old 01-20-2006, 08:36 PM
Most Chevy wheels should fit fine. Chevy had the same 5-lug bolt pattern for compact thru full-sized cars through 1970, but from '71-'76, they went to the big GM pattern for the full-sized cars. After '76, the big GM cars could have had either pattern.
If the Skylark has disc brakes, some of the older (pre-'75) Chevy 14" wheels won't clear the calipers.
Old 01-21-2006, 08:19 AM
Tazz
I had a set of 78 Impala wheels
They were factory rallies off a 78 Impala Wagon..wouldn't fit any other GM car's I had around. I pulled off the tires and sold the rims.
Tazz
Old 01-21-2006, 09:09 AM
Rob Keller's Avatar
Wiki Edits: 38
Does Any one know what the actual bolt patterns are ?
For the record
Rob
"SlowRide66"
Old 01-21-2006, 11:33 PM
Big GM is 5 on 5", small is 5 on 4-3/4".
Old 01-21-2006, 11:54 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
http://www.mrt-wheels.com/boltpatternref.html
http://kxwheels.com/fitment.cfm
http://www.discountedwheelwarehouse...._Reference.cfm
In general, all GM non-metric wheels from 72 to present go something like this:
All full size (B and D body) cars, 5-lug full size pickups, astros and the like have the 5x5" pattern. All intermediate RWD cars (A, G, X, bodies), S10s, and AWD astros have the 5x4.75" pattern.
The problem is that Chevy rallies came in both patterns. Do you know which vehicle they came from?
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
55 chevy? about using 84 buick disc brakes DeathByGreaser Suspension - Brakes - Steering 2 04-26-2003 07:43 PM
Buick V8 to Chevy trans Smonska Transmission - Rearend 7 04-12-2003 03:58 AM
Nailhead Buick Manual Flywheel(s) DJM Transmission - Rearend 2 11-09-2002 06:51 PM
