Chevy S10 Trans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2006, 08:26 PM
Chevy S10 Trans?
I'm wanting to put a small block 350 into my 1985 chev s-10 4x4 and i need to know what trans would work best, cuzz i know the 2.8 trans will not work anyone got sugestons? or will it work somehow?
Old 02-25-2006, 09:01 PM
427v8's Avatar
C6, the C5 of tomorrow
Wiki Edits: 7
A friend of mine has a 12 second s10.
It has a sb400 backed up with a TH700R4.
The V6 S10's came with that trans, but it IS beefed up a little ;-)
Old 02-25-2006, 09:06 PM
The 700 has overdrive too. That is one of the things I liked about the s10 I had way back when, although the 2.8 wasn't much of an engine.
Old 02-25-2006, 09:12 PM
smallblocker2's Avatar
L79 327 5SPD S10 '65GTO
If you want to go manual. get a 96-up S10 4.3 4x4 tranny from like a ZR2, aka NV3500. Mines taken a pounding for 4 years. As for auto? I don't know.
Old 02-25-2006, 10:19 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
You have a LOT of options available to you having to start from scratch.
Manual or automatic?
Overdrive or not?
Stock or stronger than stock?
Stock automatics were TH-700R4, followed by the same thing only renamed to 4L60, then replaced by the electronically controlled 4L60E.
Manuals went from Borg-Warner 4-speed, to a Borg-Warner 5-speed (T-5), NVG-1500, NVG-3500, and maybe a couple others over the years.
You can change it from automatic to standard, or the other way around, just by searching junkyards if you choose to go this route.
454 chevy in 79 trans am, possible? Trans Am Benny Engine 9 12-31-2011 12:06 PM
Engine build ideas Rug Engine 23 12-25-2006 02:39 PM
Chevy s10 Xtreme 4.3 V6?? Mightymouse Engine 5 04-27-2005 09:16 PM
Chevy motor and trans dimensions Neophyte General Rodding Tech 4 06-04-2004 05:31 PM
choping the top on a 89 chevy S10 Bd Body - Exterior 0 05-19-2003 07:51 PM
