chevy sb 350 project - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 05-13-2013, 07:13 AM
Hello.I'm not a mechanic so I'm trying my best.Work with me lol.I have Chevy SB 350 headers,eldebroc intake and cab,msd ignition and coil.I brought my 350 block in 2011 from Jegs.Basically I want to installed a can and replace the heads with aftermarket heads aluminum.I have a (comp cam 474 lift).I'm just reading off the paper.I also have a summit cam but after doing alittle research the (Comp cam) is for sound and my summit can too little.Basically I have $1500 left in my budget and I'm trying to get close to 400 HP as possible.Somebody help me please.Oh yea.Remember I have a 2011 Chevy SB 350 so at lest I got a new block.Thanks guys
Old 05-13-2013, 09:17 AM
350 Chevy Project
I would suggest that you spend some of your budget on a experienced engine guy who will help you.
The Following User Says Thank You to Biothree For This Useful Post:
youngprince23 (05-13-2013)
Old 05-13-2013, 01:43 PM
My best friend is a certified mechanic.Really i just need a good cam and heads.
Old 01-05-2014, 03:23 PM
too CAM or not to CAM ?
have you considered punchin that block out to a 383 stroker, I did one back in 08, performance in Tucson did the punch 30 ov then I shopped around for a set of keith Blk pistons slid a mild rv cam, eldelbrocked the top end with Mallory and msd, through some cheep performer headers with 3' flow dyno'd at 410hp, but my opionion on the cam 400hp is gonna be nearly impossible. good luck young man
Old 01-05-2014, 03:28 PM
oh my bad I am a mech. and have been proudly playing with these here 350 since about 1962. I did the complete build for around 2800.00 parts and punch. I could of saved around 800.00 going with a off brand piston.
Old 01-05-2014, 03:51 PM
jokerZ71's Avatar
Wrench Turner
Did you just buy a block,or,did you buy a crate engine?If it's a crate,which 350 is it?
350 Project allansmith859 Hotrodding Basics 3 03-15-2012 01:41 PM
chevy 350 project camaro8791 Engine 9 01-20-2011 02:21 PM
350 Chevy Buggy Project 350quadchevrolet General Rodding Tech 3 09-05-2010 03:28 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
Engine project (newbee) chevy 350 Hazard Hotrodding Basics 0 03-22-2005 10:04 PM
