Chevy SB Starter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2005, 06:48 AM
tay tay is offline
New Member
The last post "won't crank anymore" has developed a new question for a newbie like myself. The starter did not engage the flywheel completely. I shimmed it down and can see that the bendix gear will fit into the flywheel teeth. While looking at this, I noticed a bushing looking part on what I'm calling the bendix shaft, which is the shaft that the bendix gear slides on.
Going from memory, I don't remember seeing this "bushing" on other starters. Anyone help me with this? I think my starter has broken and the bushing should be elsewhere.
As always, the help is greatly appreciated.
Tay
Old 08-31-2005, 09:14 AM
Sounds like your starter drive has failed. There is a bushing under the teeth that rides on the shaft. If it was mine I would probably change out the drive-For a "Newbeeeee" I think you should replace the starter as a unit with a reman from the parts store and be done with it, especially if your starter is more than a couple years old.
Old 09-01-2005, 07:54 PM
There's a stop collar about 1/8" long that lives between the starter drive (bendix) and the snap ring.
http://www.v8mr2.com/reference/Starter.pdf (scroll down almost all the way & there are some exploded views)
Is this what you see? It usually snaps onto the snap ring, but sometimes it will ride on the shaft in between the ring & the drive gear.
Old 09-02-2005, 07:08 AM
tay tay is offline
New Member
Found the problem - Thanks
I changed the starter and the problem "went away".
Thanks JimFulco,
It would appear that the parts you mentioned (great exploded diagram) were the culprits. Part #6 was loose on the shaft, and would stop the bendix gear from engaging (I think).
In any case, thanks to all. I got the 383 started last night and it was largely to the help of you at Hotrodders.
Thanks again,
Tay
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
350 Chevy Starting question ThumperCR Engine 5 10-31-2004 10:37 PM
72 chevy starter skbackdoc Engine 9 10-31-2004 06:03 PM
72 chevy truck starter skbackdoc Introduce Yourself 3 10-19-2004 08:20 AM
chevy starter, quick q- killerformula Electrical 2 07-01-2004 10:05 AM
