Chevy SBC, finding TDC without timing marks - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2009, 05:36 PM
04SilveradoMykk's Avatar
Hey Guys,
Thanks for all of your help & input thus far, I've got my SBC back together & driving.
I did notice something strange though, this morning I set the max timing to 34 degrees with the vacuum advance unhooked. The idle landed at 21 degrees advance. Yet the engine cranks & fires up just fine, theoretically wouldn't 21 degrees of advance at idle seriously fight the starter motor while cranking?
Perhaps what I'm seeing as 21 degrees of advance when the timing mark's align isn't nearly that high in reality, like the marks are off.
Is there a way I can find TDC of #1 without relying on the timing marks of the balancer & timing cover?
This SBC has Vortec heads, I do have a dial indicator. I have no problem pulling the valve cover to see the Int valve close. Am I on the right path here? Would a dial indicator even get down the long reach spark plug hole and touch the top of the piston with vortec heads?
Am I just making extra work for myself, and a Chevy SBC will crank with ease using 21 degrees of advance?
Thanks in advance
Cheers ~Mykk
Old 10-25-2009, 05:46 PM
DoubleVision's Avatar
All I ever did was pull a valve cover, be assured both valves are closed, remove the number 1 spark plug and use a breaker bar on the balancer bolt. I would slip a screw driver into the spark plug hole and move the breaker bar, when I felt the screw driver stop moving up I knew I found TDC.
Old 10-25-2009, 06:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
DETERMINING TDC
TIMING TAPE
Unusual SBC timing problem 85GMCguy Engine 13 08-06-2010 05:48 AM
Timing question on 350 sbc eric32 Engine 6 08-03-2009 07:10 PM
Bb Chevy Ignition Timing leejoy Engine 13 03-01-2006 02:09 PM
305 Balancer on 350 ? timing marks off the chart BigDawgsEatFirst Engine 11 08-24-2005 12:56 PM
sbc timing question chrisgarrison Engine 6 04-08-2005 07:12 PM
