Chevy shorter coil spring problem, HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2012, 01:56 AM
tenacious101010's Avatar
I put shorter than stock coil springs in the front of my 88 chevy truck frame. (I also installed lowering spindles.)The truck sits lower as I needed it to but issue that has arisen is that the lower A -arm is now almost level with the ground which means that the wheel is moved further outboard from the centerline of the truck. This alone is not a problem but the problem is, the front suspension can not be aligned properly because the top arm attach bolts are not long enough to add the required number and size of shims to get the wheels where they need to be. I have looked at the possibility of installing longer bolts, but that is a big job. Another option I have considered is to redrill and remount the u-bolts that locate the lower a arm about 1/2 inboard of their current location. This would move the wheel inboard enough that I can get the proper shims in place to align the front suspension. Anyone have any experience with resolving this problem and how did you resolve it?
Thanks, Denny
Old 02-05-2012, 09:11 PM
If you lowered the a-frames to level with the floor, that has to be around 3"- 3.5" coils alone. That truck is insane with drop spindles. How low did you go? I've killed two trucks personally 75 and 76 going too low. Are you sure the a-arm bushings are good? If they are, relocating the lowers may be the easiest. I've never attempted that but you go for it.
Thanks, Denny
Need help on shorter length pulleys and chevy water pump grobb284 Engine 10 05-23-2009 01:24 PM
Coil spring rear suspension for 52 chevy coupe AustinPhoenix Suspension - Brakes - Steering 6 03-14-2009 09:27 AM
Coil spring for 350 on a S10 GMC1950 Suspension - Brakes - Steering 5 02-29-2008 10:29 AM
'65 chevy P/U drop spindles or coil spring change? dar130 Suspension - Brakes - Steering 6 02-02-2008 11:27 AM
57 Chevy Spring problem uskdab01 Suspension - Brakes - Steering 1 11-28-2007 07:59 PM
