chevy silverado - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2011, 07:56 PM
hotrod3z's Avatar
Last journal entry: my first project
chevy silverado
i have a 96 chevy silverado 5.7 vortech last night i shut the truck off then 2 hrs later it wouldent start found out the fuel pump went out so i replaced it then it just wouldent start again i replaced the ecu and camshaft sensor i have a real hot spark and fuel to the intake but for dome reason the injectors wont send any gas in to the cylinders but i poured gas in the throttle body and it started up could any one help me with this problem thanks
Old 01-27-2011, 08:14 PM
check fuel pump and fuel fuse. a friend of mine had a similar issue just before xmas. He had the fuel pump replaced the cpu replace. then he called me and it took me a while and i found it by accident but there was a broken power wire. got it hooked back up and fired right up.
Old 01-27-2011, 08:25 PM
I'm not sure about that year but some of those gm vehicles have to have the crank sensor re learned after being installed. if your injectors aren't firing but you have fuel pressure at the rail then the crank sensor isn't telling them to fire.
Old 01-27-2011, 08:26 PM
hotrod3z's Avatar
it is getting fuel at the intake
Old 01-27-2011, 08:34 PM
i'm sorry i meant camshaft sensor not crank.
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e trans Willbee26 Transmission - Rearend 3 03-28-2010 10:40 PM
2002 chevy silverado nickman2002 Engine 7 03-16-2010 11:18 AM
'99 Chevy Silverado '99 Chevy Silverado Transmission - Rearend 7 11-22-2007 01:32 PM
95 chevy silverado tripp68 Transmission - Rearend 5 10-04-2007 08:53 AM
'88-'98 Chevy Silverado dannimo Interior 1 08-13-2003 08:53 AM
