chevy small block - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2009, 10:46 AM
chevy small block
I have a small block chevy motor. I can hit 9 grand on the tach. The motor is all original. The most powerful small block i have ever had. The casting number is 3970010. The engine VIN code is 12J11369V005CKB. Can you please tell me what this is. I'm trying to figure out what type of engine I have on my hands. 7400 without floating the valves on a relay tach. 3in stroke, 4in bore, and a 11:1 compression, and has an original holly 800 dual feed carb 3910.
Thank You,
Tim
Old 01-22-2009, 11:04 AM
SSedan64's Avatar
Thank You,
Tim
http://www.chevymania.com/partsid/pa...=block&block=S
Casting Number- CID---- Years--- HP----- Comments
3970010----- 302/350- 69-79--145-370-- car & Truck 2 & 4-Bolt Most common
http://www.chevymania.com/partsid/su...fm?block=Small
Code-- Year--- CID-- Vehicle--- HP-- RPO-- Trans-------- Carb----------
CKB---- 72---- 350-- Chevelle- 165-- L-65- Power Glide--- 2-Brl----------
CKB---- 73---- 350-- Nova---- 175-- L-48-- Manual------ 4-Brl----------
CKB---- 73---- 350-- Chevelle--175--L-48-- Manual ------4-Brl----------
CKB---- 73---- 350-- Camaro-- 175-- L-48-- Manual------ 4-Brl----------
CKB---- 74---- 350-- Nova---- 185-- L-48-- Manual----- 4-Brl-----------
CKB---- 74---- 350-- Camaro-- 185-- L-48-- Manual----- 4-Brl----------
CKB---- 77---- 350-- Impala--- 170-- LM-1-- TH 350---- 4-Brl----------
Old 01-22-2009, 01:53 PM
no help th the shops tell me when the entire vin is in the block then a performance shop did it
Old 01-22-2009, 02:02 PM
ktorr22's Avatar
Sbc
If your hitting 9000 the engine isn't stock, 010 blocks were used for 69 302 and 327's and a bunch of years for 350's what is the casting # on the heads? if the last three digits are 186 you could have a 302 Z28 engine, if so It's worth some big $$$ there pretty rare now days, either way It's not stock hitting that RPM
Good luck
Old 01-22-2009, 02:03 PM
302 Z28's Avatar
Respectfully, I think your tach needs re-calibrating.
Vince
Old 01-22-2009, 02:07 PM
302 Z28's Avatar
Never heard that one before.
Vince
Old 01-22-2009, 02:13 PM
poncho62's Avatar
Wiki Edits: 5
I had a 327 that hit 9000......once......Then, it was making this funny knocking noise......
I had this other friend, that had his tach set on the 6 cyl setting...........
Old 01-22-2009, 02:19 PM
302 Z28's Avatar
LOL, I was gonna suggest that.
Vince
Old 01-22-2009, 03:33 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Which shop told you that? I'm in Wausau too, and I'd love to know which shop to avoid....
In a while, Chet.
Old 01-22-2009, 07:25 PM
SSedan64's Avatar
I think you or they got that one backwards, a performance shop may mill/deck the block & the factory VIN#'s stamped on pad at passenger side front of block would be gone if it's decked enough.
Old 01-23-2009, 08:48 AM
Thank You,
Tim
That would suggest a DZ 302. They are the motor that GM won the '67 and '68 Trans am races with. One of the hottest factory motors they ever made and highly sought after by collectors. Is it in a Camaro? If so you may have a very valuable car..
small block chevy engine id code help princesswz Engine 22 01-03-2015 12:15 PM
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 11:46 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 08:26 AM
Chevy small block fuel injection homesimpsonr Engine 7 05-19-2007 05:11 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 09:35 PM
