chevy small block 305 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-25-2013, 12:59 AM
spinn's Avatar
He got me, like he got you
Originally Posted by oldbogie View Post
For the cost of stroking the 305 you can build a really great 350. Not that I'm opposed to 305s but on a cost to benefit basis it isn't worth doing this to the 305. You end up with 20 inches less engine, no weight benefit ala 347 vs 351 Ford, all for the same or more cost as a 350.
A stroker crank does not make more torque, the torque is simply a displacement function more equals more, less equals less; PERIOD! The only thing diddling the bore to storke relationship does within a fixed displacement is move the RPM around where the peak occurs, not the amount. Longer stroke lowers the max RPM where the peak occurs, shorter raises that point. For an otherwise idential configuration of parts that's all that's happening.
Bogie
The torque number might be a little higher in a identical engine size comparison.
Your point is alright for me. The 3.73 gear can be got cheap online.
Chevy small block 305 question RICK JAMES Engine 8 11-08-2012 08:49 PM
Need help wiring a chevy 305 small block?? seanwr30 Engine 9 03-16-2011 12:13 PM
305 heads for my 307 small block chevy alexcamaro307 Engine 6 12-23-2010 09:16 AM
305 small block chevy hp. stickshift Engine 18 04-08-2005 10:47 AM
1986 305 chevy vs. 1987 305 chevy new style small block mtinsley Engine 2 08-22-2003 11:55 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
