Chevy Small Block 400 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 09-07-2006, 05:57 PM
i AM NEW TO HOTRODDING. i LIVE IN ARIZONA, RETIRED LIKE DRAG RACING I HAVE 68 NOVA WITH A 400 BLOCK 30 OVER TWO SPEED POWER GLIDE 1.76 GEAR 411 REAR END. 26 INCH 10,5 DRAG SLICKS. ANY PROBLEMS WITH THE STEAM HOLE ON 400 BLOCKS LIKE CRACKS IF SO CAN IT BE FIXED. ANY HELP. THANKS TO ALL
Old 09-07-2006, 07:31 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to the Hotrodders Bulletin Board.......we are glad that you found us...hope you enjoy the site. You really need to ask your question in the Engine forum.
Old 09-07-2006, 08:57 PM
BOBCRMAN@aol.com's Avatar
Steam hole cracks can be repaired. If they don't go to a cylinder. Most go to a head bolt hole. These are repaired by drilling and tapping the steam hole for an "Iron stitch" tapered plug. The plug is then thread sealed (Goodson white sealer), Installed tight in hole. After sealer is set, re-drill the steam hole just slightly smaller than the original. The remaining tapered plug threads seal off the crack and no more coolant creep up the studs.
I have done many 400's this way.
small block chevy cam change hardsixstring Engine 1 05-23-2006 06:38 AM
i'm looking for a better 400 s chevy block 406 ss monte Engine 3 08-23-2005 07:48 PM
chevy 400 block??? chevelle434 Engine 8 02-14-2005 12:05 PM
283 small block chevy? Balz Engine 3 06-11-2004 10:22 AM
400 small block re"performance"build 78 monte Engine 2 04-19-2003 07:32 PM
