Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy small block blower install tuning issues.
Old 07-22-2004, 11:07 PM
subman17's Avatar
subman17 subman17 is offline
I looked around and could no info regarding this except for posts regarding people not liking pertronix kits so here is my question.
I have just completed installing a Holley/weiand 142 blower in my 1969 Chevy c-10 pickup. I am running a brand new Edelbrock 1413 carb, Holley 110gph mechanical fuel pump, and an MSD Boost timing module. It started right up first try, and idled perfectly. It was smoking a bit cause I set the carb up too rich, so I took it back down to the stock metering rods and jets. It now still purrs like a kitten at idle, but when you take it to 1500rpm or more, it misses like crazy. It shakes the truck when you bring it up through the RPM slowly from 1500 and up. If you just burp the throttle, it revs up smoothly and no miss. I am running an MSD 6al, and the boost timing control box. I have the stock points style distributor, with a pertronix conversion kit in it, and an MSD cap and rotor. I think it is the pertronix set up causing the problem even though it ran fine before the install, all we did was change the cap and rotor(which could have knocked the pertronix out of whack) I check the timing, looks fine, and we even played with different timing settings, no difference in the rough running issue. So anyways, to make a long story short, should I just break down and get an MSD distributor model 8361 and junk the pertronix, or is my problem elsewhere? Thanks for the help and suggestions!
