chevy small block engine code ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2012, 07:00 PM
I have a small block chevy and the code on the front of the motor is "V0510TDA". The code right under that is C8F503926. the code on the back drivers side Has 41GM and right above that is 70010. it also has a dial circle with 10dots with a dot above the top dot and a pointer pointing at the 10th dot. on passenger side back is the numbers 383 and a large S right above the starter. all i have been able to find out is it can be several different blocks. If anyone can help me out here to find out what it came out of and what year it is this will be a great help.
Old 07-10-2012, 08:42 PM
DoubleVision's Avatar
TDA 72 307 Truck 135 L-14 Manual 2-Brl C 10 & C 20
TDA 80 350 Truck 165 LS-9 TH 350 4-Brl
70010 indicates this is a 350.
chevy, engine identification
small block chevy engine id code help princesswz Engine 21 01-03-2015 11:15 AM
ME code on 60's small block chevy dscustomfab Engine 1 11-20-2011 10:18 AM
small block 350 engine code juggalo360 Engine 32 04-26-2011 08:09 PM
I need help with small block engine ID chevy jklmbrand Engine 7 08-31-2006 05:36 PM
Small Block Chevy Engine Id 327amc Engine 3 01-04-2004 03:50 PM
