chevy small block head decking - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2013, 10:04 PM
if you beat my boat, well race
how much material can i take off a 64cc "fuelie" head before the intake runner should be cut?
Old 05-23-2013, 05:59 AM
vinniekq2's Avatar
I would not spend any large amounts of money on heads that are 45 years old.
and,,,,I do not quite understand your question
Old 05-23-2013, 06:14 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
It's illogical to boost the compression ratio on a head that doesn't flow well enough to warrant the increase.
Old 05-23-2013, 07:01 AM
@ 9.1:1, i need all the help i can get! these heads have been opened up a tad.
Old 05-23-2013, 07:26 AM
Check out this link:
http://www.crankshaftcoalition.com/w...cylinder_heads
ssmonty
Old 05-23-2013, 07:52 PM
Proud LOSER
0.014 milling will bring you around 62cc's
Then use this head gasket
http://www.summitracing.com/parts/fel-1094
If I'm right this puts you at 9.7:1
I'm guessing by your math, stock deck, small dish stock piston SBC.....?
Gen 1 Small Block Chevy 350 Head Gasket Question 71fj40guy Hotrodding Basics 8 02-25-2013 05:55 PM
How to tell apart the differences between small block Chevy cylinder head valves? DEMONSPEED Engine 7 01-02-2010 06:55 PM
small block head casting #s JOE JOE Engine 5 01-23-2009 07:08 PM
Small Block Chevy head selection 701/2Camaro Engine 3 01-11-2009 10:56 PM
which small block chevy cylinder head? pds23 Engine 2 07-22-2008 07:19 AM
