Chevy Smallblock 327 Specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2003, 08:16 PM
ToYoungToCare's Avatar
i recently aquired a 327 chevy small block engine for my 1967 chevy camaro. Its been sitting for a good 10+ years so i am going to have to rebuild it. The previous owner of the engine said he rebuilt and it has never been run. He said it was bored and and has a racing cam and some other goodies able to produce 350 ponies. On rebuild everything looks new and unrun, but to check everything the guy said i was wondering if anyone knows themselves or can tell me a sight that will give me all the original specs for my engine? Any information would be gratefull thanks to all.
Old 08-15-2003, 04:54 AM
302 Z28's Avatar
Try www.chevymania.com The little 327 was availiable in hp from 250 to 375 from Chevrolet.
Vince
Old 08-15-2003, 07:43 AM
Hey thanxs for the sight its a great sight.
Old 08-30-2003, 03:13 AM
LiKeArOcK's Avatar
New Member
327 has a 4.0 in bore and 3.25 in stroke..Advertised displacement 327 ci actual displacement 326.7 ci.....Max overbore is 0.060 in...It was produced through 62-69....Horsepower range 150-235 net 210- 375 gross...adv. compression ratio 8.75-11.25:1....Main journal diameter 2.30 in 62-68.....2.45 in 68-69....Rod journal diameter 2.00 in 62-68.....2.10 in 68-69....Conrod-rod center to center 5.7.... Con_rod bolt diameter 11/32 in 62-68....3/8 in 68-69....Main bearing cap two bolt.Crankshaft forged steel 62-68....cast iron 68-69....intake-valve size 1.72/1.94/2.02 in.... exhaust valve size 1.50/1.60 in... What did they come in 67-69 camaros 64-68 chevelles 65-68 chevy ll's/novas 62-68 corvettes 62-69 fullsize passenger cars 62-68 trucks... The best 64-65 375hp l-84 corvette fuelle.The worst was the 62 180 hp c60 2-ton conventional truck.
Most of this is out of a magazine called Chevy Small Block Engines. By Marlan Davis
