chevy springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2010, 11:43 AM
chevy springs
Hello
I recently bought leaf spring kit to install on my 40 pickup. . spring kit looks to be installed under frame ,that puts it to frame to high . Looks like it would work out to put spring brackets on side of frame . ,with modifying brackets . Using gm rear ,15 " wheels . Like to keep[ the rear of frame 13to14 inches from flloor . What would be my options ? Iwant to stay with parrallel leafs !!!
Thanks larry
Old 12-19-2010, 12:19 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
does the axle sit (mount) above or below the springs?
Old 12-19-2010, 03:10 PM
spring problem
Matt
I,ve got the axle sitting on top of the spring leafs .Trying to shoot for about 13 to 14"to bottom of frame . Can hang spring hangers on outside of frame , but have to change the way the shock mounts. Not really wanting to do that .
Larry
Old 12-20-2010, 02:23 PM
spring
hello
has anyone out there installed a rear spring kit on 40s /50s pickup?
Thanks Larry
b or g hemi joe Body - Exterior 5 05-03-2009 02:50 PM
47 - 54 Chevy Leaf Springs? KernCountyKid Suspension - Brakes - Steering 4 09-11-2006 12:48 PM
Diffrent Springs? strikingthematch Engine 3 12-09-2004 09:12 PM
Valve Springs GearHead69 Engine 5 07-19-2003 11:00 AM
need advice to move 56 chevy rear springs sglig Suspension - Brakes - Steering 5 04-24-2003 03:08 AM
