chevy starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2005, 06:19 PM
shieldbreaker's Avatar
chevy starter
what is the most common cause of the nose breakage on chevy starters?
76chevy 355 motor th 350 transmission, have broke several like this.
motor is mildly built.comp cam #12-254-3, domed pistons headers ,holley street dominator intake holey 600 cfm intake,stock style heads .
running jegs 27-3000 stall converter.
Old 01-31-2005, 06:38 PM
Matts99Sierra's Avatar
i dont really know too much about this area. but if it was me i'd say the starter is missalighned, or its catchin on something when the solenoid is engaged? that'd be my guess. or you just have really bad luck with starters.
Old 01-31-2005, 07:04 PM
poncho62's Avatar
Wiki Edits: 5
Are you using the front bracket....?
If not, it may be twisting when engaging.
Old 01-31-2005, 07:18 PM
coldknock's Avatar
No brace on the starter, a cocked housing and/or too much elbow grease.
Larry
Old 01-31-2005, 07:39 PM
A little known fact........by most of the younger crowd anyway....is that GM made a iron nose for these starters. Not all that hard to find. GM made them for both the 153 tooth flywheels and the 168 tooth ones too.
Use a front brace and a iron nose and the breaking will STOP.
We had to run both on a dirt stock car racer years ago.
Old 01-31-2005, 08:29 PM
any info as to where one can be located ?
i am using the starter bracket as well and the flexplate is in good condition.
thank you for your input
joe
