Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy starter cranks and cranks, cranks
Old 07-21-2003, 09:35 PM
Walker Walker is offline
I just got my 350 in and connected everything up. Went to bump the engine, turned the key and the starter starts cranking then won't stop. I have to pull the battery cable to stop it. When I reattatch the battery cable nothing happens until I turn the key back to start. I checked the wiring and is correct as per the manal and is the same way as when I took it off. Could this be a solennoid problem, or should I look into the starter wiring?
