Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy starter issues...
Old 03-26-2012, 07:53 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
EOD posted a good view of the starter wiring. The '79 motor used an HEI dizzy so no I wire is needed from the starter to the coil.
A solid copper wire will be needed from the ignition switch to the dizzy. Remove the existing '66 wire. This '66 wire was a resistor wire that was used with the old point type dizzy.
vicrod
