Chevy starter issues... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 04:21 PM
Ok, so here's what is going on. I have a chevy 350 from a 79 camaro in a 66 buick skylark, and I'm using a starter from a 1979 camaro. The starter is toast per Pepboys. I have the engine out right now, and for the longest I have been starting the car with a push button because my ignition wasn't working. So I got adventerous and fixed the ignition, wired the starter up and BOOM, starter body arc's (it was sitting on the car frame) against the frame of the car.
I guess maybe I burned it up, or the starter is just bad from sitting all winter without being used. I am using the wiring diagram for a 66 skylark, assuming the wiring terminology would be the same somewhat, except, I don't know the terminology behind wiring a starter. If someone here could give me the basics of wiring a solenoid, what each post does, and how the ignition actuate's the starter, I would appreciate it. I would also appreciate links, because all I can find is Ehow crap that doesn't really help. Thanks
Old 03-26-2012, 06:15 PM
EOD Guy's Avatar
Should answer your questions as far as how it wires up...... If you are running an HEI dizzy, you don't need the wire from the "I" terminal to the coil..... that's only for points type dizzy
Name:	chevy starter dia.jpg
Old 03-26-2012, 07:53 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
EOD posted a good view of the starter wiring. The '79 motor used an HEI dizzy so no I wire is needed from the starter to the coil.
A solid copper wire will be needed from the ignition switch to the dizzy. Remove the existing '66 wire. This '66 wire was a resistor wire that was used with the old point type dizzy.
vicrod
Old 03-27-2012, 02:42 PM
lg1969's Avatar
Google "Tunnel Ram 406"
You have be careful when wiring the the ignition system. The reistor wire that connects to the plus side of coil is now used on the HEI will not work. You need to by-pass the resistor wire for the HEI. Another problem when you try to crank the motor, there is no 12 volts feeding through that wire. The "I" terminal takes over and feed to the plus terminal coil or the batt terminal on a HEI. I ran into street rod that had a GM steering column with the key switch on the column. He ran into a problem where he would crank the engine and it would not start right away. As soon he let go the key it started. Sure enough I put a light on the plus terminal of the coil and the light was on in the "on" mode, as soon he cranks the engine the light would go out. Turn out he did not had a wire at the "I" terminal soloniod to the coil. When I connected the "I"terminal to the coil it started running right away as soon when he cranked the engine.
Old 03-28-2012, 03:57 AM
EOD Guy's Avatar
If you go HEI, elimnate, the "I" terminal wire and the old resistor wire and run a new wire from the ing switch that's hot in start and run.
Old 06-10-2012, 11:27 AM
Hoptup32's Avatar
Sorry, posted to wrong topic.
Old 08-22-2012, 12:01 PM
Recently purchased a Chevy 1950 Pick Up with 350 engine with headers. The starter is acting like they used to back in the day and you had an overheat problem and had to let the engine cool or tap the starter with hammer to get it started. Headers appear to me to need a shield between the starter and the header to cut down on the heat. I'm putting a new starter on just in case and Alternator needs replacing as well, also new battery cables. I'm hoping this action plus a heat wrap on the headers or wrap for starter will help as well.
ANY SUGGESTIONS as to what else I can do. Thanks Rooster
Old 08-22-2012, 04:30 PM
EOD Guy's Avatar
sounds like you have it covered
Old 08-22-2012, 07:29 PM
astroracer's Avatar
Switching to a Ford style solenoid will solve all of your problems with non of the wrap or heat shield nonsense... Go here and do a little reading...
Catalog
Old 08-23-2012, 04:05 AM
EOD Guy's Avatar
They make a heat shield for the starter, mine works well for me. IMO the Ford soleniod isn't the cure-all that some think it is, the bendix and starter motor, sill get very hot with or with/out the Ford soleniod...... the heat shields cut down on the amount of heat that gets to the bendix and starter motor
Old 12-10-2013, 08:40 PM
vicrod
SOLID copper wire??
Old 12-11-2013, 10:10 AM
vicrod's Avatar
life is a ride
opps
#14 stranded copper wire should be used instead of resistance wire found on point type ignition systems.
vicrod
starter issues 83 sierra classic Transmission - Rearend 37 08-15-2011 08:09 PM
Starter Issues 40Chev_13 Engine 4 03-17-2010 02:48 PM
Chevy Starter Issues Q & A Rob Keller Electrical 23 04-05-2009 08:56 PM
flywheel starter issues 350 Chevy Gearhead9000 Engine 2 01-16-2009 05:37 PM
More Starter Issues lostinthought Engine 11 11-09-2007 10:26 AM
