Chevy Starter Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2007, 09:41 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Question Chevy Starter Problem
Hey Y'all
I have been having a intermittent starter problem .
intermittent as it has happened 3 times & fixes it's self before I can figure it out.
The problem is it wont crank.
The truck is a 1988 Chevy Dualie with a 1980 400 standard shift & 3 wire solenoid
It happens like this. . .
I drive it & then I go to start it & no crank if I turn on the dome light you can see the light dim slightly ,so after numerous attempts ,I crawl under it I wiggle & tap but nothing .
So approximately 5 ~ 10 minuets later It will bust right off before I can find the problem{S}.
I am speculating a defective solenoid or a loose connection ...possibly a bad clutch safety switch..
Any ideas?
Thanks for your time
Rob
"SlowRide66"
"Illegitimis non carborundum"
Old 12-20-2007, 09:59 PM
life is a temporary assignment
Originally Posted by Rob Keller
Hey Y'all
switch..
Any ideas?
Rob
Sounds like the clutch safety
switch..
Old 12-20-2007, 10:04 PM
poncho62's Avatar
Wiki Edits: 5
Are you saying the problem occurs when the engine is hot?
Could be a heat sink problem....a heat shield may help.
Old 12-20-2007, 10:10 PM
I had a problem with my starter getting hot on my big block Chevy,Put a mini starter no more problem.
Old 12-21-2007, 07:10 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I had the internals of the solenoid fall apart in my 79
Sometimes it would start---sometimes no
Kinda aggravating, as there was no click, do dimming of the lights--nothin'
Changed the solonoid-----no problem since,
This was probably 10 years ago.
Same thing on the 66 Elky, but I had missing teeth on the flexplate as well.
sometimes it would grab the teeth, somtimes no, AND somtimes nothing would happen--no click, no light dimming, -- just silence and the realization that I may not be going anywhere soon
72 chevy starter skbackdoc Engine 9 10-31-2004 07:03 PM
starter problem ? timing problem? 6speedwagon Engine 1 08-11-2004 12:37 PM
Starter Problem Update MI2600 Electrical 1 06-23-2004 05:45 AM
Re: starter problem posted 11/11 Bob88 Engine 1 11-24-2003 08:58 AM
Starter problem Bob88 General Rodding Tech 3 11-23-2003 05:14 PM
