Chevy starter problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2009, 11:39 AM
Ok so I've read most all the posts concerning this topic. I have a 73 Chevy Nova with a 350 out of a 70s c10. All new bolts. Brand new starter from autozone... so yea it may need to be ground from what I've read. Shimmed ungodly amount still cant get it quite right and sounds like crap. All I need to know is should I go buy a "ACDelco from a Mom and Pop parts house" or should I work with the one I got... I mean would autozone even take it back? Any and all info will be GREATLY appreciated.
Thanks in advance.
Troy
Old 09-09-2009, 09:55 PM
fast68's Avatar
likes chevy trucks & boobies
have the right nose cone for the right flexplate or flywheel diameter?
no shims ?
will not need any shims with unmodified nose cone and engine block
if it needs shimmed then it is the wrong nose cone and plate/wheel diameter, or someone has milled the nose cone mounting surface down, or the starter mounting pad of the engine block
or the starter is defective
need some more info here
Old 09-10-2009, 08:35 AM
Small flywheel... correct starter... no modifications have been made to starter or engine block just a regular 350 block with a new starter from autozone... duralast or something like that... Wondering if the ACdelco's are a better fit? less trouble?
Old 09-10-2009, 11:03 AM
302 Z28's Avatar
Are you using the proper "starter" bolts or generic hardware store bolts?
Vince
Old 09-10-2009, 03:23 PM
S10 Racer's Avatar
http://www.warsprints.com
Thanks in advance.
Troy
Automatic or manual tranny? Did you change the flywheel by chance? If it's an automatic with a flexplate, I've seen people put the flexplate on backwards.
Old 09-10-2009, 08:52 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Thanks in advance.
Troy
Troy.. You said one of your problem's right here... I have had problem's with their starter and the pass... I don't buy any from Auto zone anymore... I think it has something to do with their cheap starters... Went to the mini starter's and no more trouble... I also got some bad ones from Napa also... I'm not sure what's happening here... But this seems to be a daily problem on the sbc's now..I hear a lot of people talking about this problem...
Old 09-11-2009, 08:08 AM
302 Z28's Avatar
I also quit buying starters from the parts houses, they are all off shore. Since I bought my Powermaster Ultra Torque I have had zero issues with starters.
Vince
400 sbc starter problems, Cracked Block. Adapter kit needed? tiresmoke55 Engine 7 04-16-2011 03:28 AM
350 Chevy starter pinion to flywheel clearance Bonehead4x4 Electrical 8 03-28-2009 03:49 PM
84' S10 conversion problems (starter) thumper040392 Hotrodding Basics 9 12-31-2008 07:39 AM
Starters And Vehicle Starter Problems Dutchman Electrical 3 07-26-2004 02:34 AM
starter problems 73chevyhelp Engine 3 05-15-2004 02:49 PM
