Chevy steering wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2009, 03:38 PM
41 kustom's Avatar
I've been told that any Chevy steering wheel will fit any Chevy column regardless of year. I would like to put a 60's wheel on a 70-80s column. Can I do it?
Old 09-24-2009, 04:25 PM
poncho62's Avatar
Wiki Edits: 5
The spline may be the same, but I think it would look funny....70s-80s columns were fatter than 60s columns........
Old 09-24-2009, 06:16 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Spline is the same----columns are fatter on the later columns as Poncho pointed out.
They can be made to work---Ididit sells a ring to fill the gap and quite possibly the necessary stuff to make the turns work.
The cancel cam (or pins) are on the base of the wheel on the earlier wheels, where the cam is a separate part that fits between the wheel and turn switch. (also part of the horn contacts)
Old 09-24-2009, 07:38 PM
41 kustom's Avatar
I didn't think the wheel its self made the turn signals work. There is a cam below the wheel nut is'nt there? The wheel is the last thing to go on. Thanks for the info though, I will check on the parts you mentioned.
Old 09-24-2009, 08:06 PM
41 kustom's Avatar
Checked Ididit and I see what you are talking about, I'll call in the morning and see what he has.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
what is the cheapest way to stuff 18in or 20in wheels under my 55 chevy? tiresmoke55 Suspension - Brakes - Steering 4 01-29-2006 06:11 PM
78 chevy truck steering very loose chevy2kss General Rodding Tech 10 02-20-2004 09:00 AM
power steering 48 chevy coupe ksm Suspension - Brakes - Steering 1 06-18-2003 08:45 AM
