Don't know where you got the c/n info from but here's some more info on casting numbers, etc. Here are some more. Good luck. |
So far what I have found out is the head on this motor is from a 194, the block is either a 230 or 250, and the casting number is wrong. The motor in every way matches the low deck. As for the 292 low deck, it was a thing done for circle track racing in the 80's according to some folks on another forum. They would machine the crank from a 292 to fit into a 250 block and do custom rods and pistons to build a stroker. Rumor has it there's a book somewhere by a guy named John thawley with all the details. as for the motor, I guess I'm building a 250. Thanks for the input.
Might want to cc the head, if it's 61cc like I see listed that'll put the cr up there pretty good on a 250. |
I'm not sure what you mean by suffix. If you could explain, I would like to know all I can about this engine before I tear into it and put it in my truck.
The numbers I have are; Block casting: 3788378 Head casting: 3824435 Pad behind distributor: S19754 Rear passenger side: CON3 A 30 2 That's all the numbers I can see without stripping all the paint off the block for a closer look. If those numbers have the suffix you're talking about please do fill me in. Thanks. |
"A 30 2" is a date code: Jan 30 of a year ending in 2. If this is a 250, that would be 1972. The suffix (also called the "application" code) will be in a string of letters and numbers. The string is usually a letter followed by a date code, followed by 1, 2 or 3 letter code. This is found in the area where you were looking near the distributor, above the fuel pump (prolly near where you found "S19754"). The suffix string of letters/numbers are always stamped in, not cast into the block like the date code or foundry ID code. Some suffix codes for '72: CAL - 250cid w/3-speed manual (Taxi) CBA - 250cid w/3-speed manual and NB2 CBG - 250cid w/3-speed manual CBJ - 250cid w/Powerglide CBK - 250cid w/Powerglide (Taxi) CDL - 250cid w/Powerglide and A.I.R. CDM - 250cid w/3-speed manual and A.I.R. CSD - 250cid w/Powerglide and NB2 Note- "NB2" refers to exhaust emissions There may also be a partial VIN number stamped in a separate string of numbers near the suffix string. If your block is missing the suffix and partial VIN, there's no way to know what the engine might have come in originally, unless there were other bolt-on clues like a carb w/a governor on it (would be on a heavy truck or bus), or if it had a large bellhousing and a HD "granny low" trans (also HD truck/bus application). If the crankshaft has a pilot bushing in it, that would mean it had been used w/an auto trans- although this could have been added later. I don't know what the "S19754" stands for. Maybe someone else can tell you more about this. |
| engine code confusion | rcross55 | Hotrodding Basics | 5 | 02-27-2012 08:51 AM |
| Engine ID Confusion! | 71vellelover | Engine | 9 | 10-11-2010 05:57 AM |
| Column Confusion 1980's Chevy Truck | Rob Keller | Suspension - Brakes - Steering | 3 | 04-22-2007 04:00 PM |
| small block chevy confusion | jjpodlas | Engine | 7 | 12-27-2006 10:32 PM |
| engine confusion | kevin35 | Engine | 6 | 01-24-2006 12:52 AM |
