Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy t-350 transmission
Old 11-21-2012, 10:57 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
rattle as described is usually the low - reverse steel plates rattle on the case.
May be a loose center support if the case lugs are worn or
the odd shaped support spring is weak or
left spring out for a solid center support spring replacement device
