I have merged your two threads together
Please do not start two threads on the same subject. It confuses the membership. Simply post in the thread to bring it back to the top, not create another thread
At the Bonneville Salt Flats, first gear is known as 130 mph. |
rattle as described is usually the low - reverse steel plates rattle on the case.
May be a loose center support if the case lugs are worn or the odd shaped support spring is weak or left spring out for a solid center support spring replacement device
| 1991 chevy 4x4, 350 engine, transmission swap? | blurrydan | Transmission - Rearend | 1 | 01-11-2010 05:52 AM |
| 350 transmission | 34rides | Body - Exterior | 0 | 06-05-2009 07:16 PM |
| DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. | Steve-0321 | Hotrodding Basics | 21 | 11-26-2007 12:44 AM |
| Chevy 350 to a Buick transmission | steveskylark | Transmission - Rearend | 6 | 07-16-2005 11:44 PM |
| Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? | mistermuscles | Transmission - Rearend | 0 | 07-18-2004 05:40 PM |
