Chevy TBI problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2008, 06:21 AM
Chevy TBI problems
I have an 87 350ci TBI motor in my rock krawler im building. It was half way wired and plumbed when I bought it. I finished wiring and plumbing it. When I start it I am getting fuel to the Throttle body but none through the injectors. I wired the fuel pump totally independant with a toggle switch due to the mess the wiring was in.
1.Will it mess up the "thinking" process of the ECU with the fuel pump not being wired through it to where it would not send signal to the injectors ?
2. How do I check and see if Im getting signal to the injectors from the ECU?
Thanks you in advance for any help......Im learning !
Old 12-30-2008, 07:28 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
See if this helps http://chevythunder.com/ Scroll down to where it says "chevy tbi general information" and start there. It tells of problems with no power to the injectors.
1987 Chevy Tbi Problems hiball Engine 6 02-10-2007 06:15 PM
Chevy TBI manifold with carb? Augusto Engine 13 02-10-2007 11:16 AM
90' Chevy TBI kohle1ce Engine 2 10-18-2006 10:55 PM
Switching from olds 350 to chevy 383... and now I've got problems matching up trannys elukas Transmission - Rearend 6 08-26-2003 01:03 PM
89 Chevy P.U. TBI ????? catdad2u Engine 1 11-12-2002 03:52 PM
