Chevy TH350 Speedo gear Questions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2008, 11:21 PM
labreejr's Avatar
In my 84 Cutlass I have.....Chevy 383 w/350 trans, 3:73 rearend & my wheels & tires stand 29.3 inches tall. I'm installing a Nordskog digital gauge cluster. It says in the installation guide that the electric speedo sender reads the pulses from the trans. My question is.........Do I have to have the correct drive & driven gears (for my rearend & tire diameter) for the gauge to read acurately? The driven gear in there now is a 19 tooth & looks white/off-whitish. I can barely see the drive gear with the trans in the car. Thanx in advance.
Old 12-04-2008, 11:41 PM
SSedan64's Avatar
This place should have what you need or be able to tell you about the pulse generator needed.
http://www.transmissioncenter.net/sp...0gear%20driven
http://novaresource.org/speedo.htm
Old 12-05-2008, 08:17 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I believe all the speedometer units from Nordskog are can be calibrated after installation (most any electric speedo is like this these days). So, it shouldn't matter what drive/driven gears you have in your trans - you'll just need to calibrate it typically against a known speed after installation. How-to should be in the documentation that comes with the unit or is probably available on-line.
Old 12-05-2008, 09:53 AM
labreejr's Avatar
Thats what I thought. I just wanted to be 100% before I got the car finished and had to back track. Thanx a bunch. The guys on have taught me soo much and saved me much more(money)!!!
TH250 pan and speedo gear powerrodsmike Transmission - Rearend 7 04-24-2008 06:01 PM
TH350 Speedometer Gear Choices skeeveman Transmission - Rearend 8 02-02-2007 12:37 AM
89 chevy 1/2 ton 5-speed truck gear oil??? tiresmoke55 Transmission - Rearend 12 09-12-2006 10:46 PM
700r4 outer speedo gear not turning? John Fabris Transmission - Rearend 8 05-13-2006 11:43 AM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 03:03 AM
