chevy tilt column wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2012, 10:33 PM
I have a chevy tilt column for my hod rod. it has white,dark green, yellow , purple, brown , dark blue, light blue , black , and light green and gray on a separate contacts. without breaking it apart I have no idea of the wiring. does anyone know where each wire goes?
Old 09-01-2012, 10:54 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Turn signal switch wiring
should have a connector on the end of it that plugs into the dash harness
of the GM car
White-----from the brake light switch----this makes the brake lights work
Dark Green ----To the Right rear brake/turn lamp
Yellow ----To the Left rear brake/turn lamp
Purple----From the flasher can----feeds the tun signals with the key on
Brown---From the Hazard flasher can---always hot for the 4-way flashers
Dark Blue----Right Front turn signal
Light Blue----Left Front turn signal
Black---Horn ground to horn relay signal
Light Green
Grey
Not too sure about these two---could be the "Key in Ignition" buzzer
But on the GM columns I have seen these wires were pink and Pink&Black
The colors of your wires kinda lead me to either some sort of light somewhere on the column or maybe a cruise control switch on the turn lever.
Old 09-02-2012, 03:10 PM
Cape Cod Bob's Avatar
Wiring diagram for 85 chevy truck column? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Maybe this thread can help.
If not Google chevy column wiring .
Old 09-02-2012, 03:13 PM
If u do a search on here you can find almost anything.
Wiring GM Tilt Steering Wheel Column
Old 09-02-2012, 03:44 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Here is the schematic for it.
vicrod
Old 09-02-2012, 05:54 PM
EOD Guy's Avatar
If I read it right.... Bryan has it correct, and the gray wire might go to your climate control light.
I've attached the dia for a 67 Camaro, GM was good about keeping the colors the same. The steering column connector the the half moon thing in the 2nd dia and if you trace it to the 3rd one, it ends up at the climate control light
ID:	67702   Click image for larger version
ID:	67703   Click image for larger version
Wiring GM Tilt Steering Wheel Column texapache Electrical 7 10-15-2010 08:35 PM
Early Chevy Tilt Column rollenhard Electrical 3 05-19-2009 11:58 PM
93 Park Ave Tilt Column Wiring info needed TooMany2count Electrical 3 01-26-2007 02:46 PM
chevy tilt and side column stuartc Suspension - Brakes - Steering 2 03-27-2005 08:30 AM
Chevy Tilt Steering Column James Groves Suspension - Brakes - Steering 1 11-20-2001 04:12 PM
