chevy tilt and side column - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2005, 01:32 AM
Last journal entry: The floor going in
Hi
dose anyone have a workshop diagram of a chevy tilt and slide column coming to bits as i need to strip my column down and wanted to see how it comes apart
thanks
stuart
Old 03-25-2005, 11:03 AM
Well these bad boys aren't too fun to take apart but it can be done. The main thing is you'll need a special tool to get the C clip out that holds it together otherwise you can take them apart by compressing the inner wheel down and prying the clip out with a screwdriver. Gotta be careful though as I have broke many plastic pieces that are within this bad boy.
Old 03-27-2005, 08:30 AM
hi
what i need to do isto get the shaft that gose into the fire wall needs to be cut down and resplined so it will fit my car i just wanted to see if anyone has a diagram of one in bit like a workshop manual picture?Then i can take it to bits for the machine shop.
thanks for the reply
stuart
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 12:37 AM
84 Grand Prix column replace info Bee4Me Suspension - Brakes - Steering 4 02-08-2005 09:01 PM
Corvette steering column loose woody51 Suspension - Brakes - Steering 4 01-28-2005 03:29 AM
