chevy timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2009, 04:53 PM
chevy timing
chevy 350 w mild cam and edelbrock 600. can anyone tell me if ill have to re time my engine after installing a pcv valve on a system that currently does not have one? ie: completely closed system.?? just for any helpfull criticism im going to be running a pvc valve on my front drivers side valve cover and run it to the front carb vacuum, and then run a filter cap on my back passenger side valve cover. - good? also right now the valve covers are capped..
Old 06-12-2009, 06:55 PM
anyone"? rlly need to know what im getting into
Old 06-12-2009, 07:02 PM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
it shouldn't have any affect on your timing.
you need to be sure the valve cover has baffles where your going to put the PCV valve. if it doesn't have baffles, the PCV valve will pull oil out of the crankcase.
Old 06-12-2009, 07:22 PM
ok so do i need baffles on both the breather valve cover and the pvc valve cover ? or is it ok to run just a breather only on the passenger side and a pvc with baffle on the drivers side? sorry im still new to this pvc system stuff. iv read alot but still tryin to get it down..
Old 06-12-2009, 08:03 PM
ericnova72's Avatar
More for Less Racer
You will only need the baffle at the suction point, which is the PCV valve.
Old 06-13-2009, 10:01 AM
bobjob's Avatar
make sure that your filler cap/ breather has a filter... don't want dirt/bugs inside your engine...
Old 06-13-2009, 08:12 PM
so should i just use a baffled breather grommet and insert a pcv valve grommett into the breather grommet and then stick in the pcv valve? ->->-> ?? thats what im gathering from looking at pictures.
Old 06-13-2009, 08:28 PM
hemi joe's Avatar
loves ex cop cars
keep pcv valve set-up the way you are thinking,run vented breather on pass. side to air cleaner,use breather with filter and line to run to air cleaner.worked for me. JOE.
Help Setting Initial Timing on Chevy V8 leejoy Engine 14 07-11-2013 12:59 PM
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 03:49 AM
Help with setting timing Big Block Chevy 71 nova Engine 3 08-03-2008 02:19 PM
Chevy 350 Timing issues Dans83Olds Engine 3 09-04-2003 02:22 AM
Timing Specs for chevy 350 engine 68_Convertible Engine 3 11-25-2002 05:51 PM
