Chevy Timing Tab ID? - See Photo - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2010, 08:32 PM
Hello, I have a timing tab that I can't read & was hoping someone could tell me what the degrees are on this one? I can read "0" but I can't read anything else to know what I am setting it at. The is the tab that sits at 12:00 and is welded on the timing cover on my 86 engine. Any help I.D.ing it would be very helpful and appreciated.
Old 05-27-2010, 08:43 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I found this in a Rod & Custom article
Hope it helps. Maybe try to get in there with a bit of laquer thinner or brake fluid to remove some of that paint. (Brake fluid works real well at removing paint. Don't ask, OK? )
Old 05-27-2010, 09:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The scale in in 2 increments. Each "outer" (downward pointing as viewed in your photo) point is 4 apart, so there are "outer" points for 4, 8 and 12 BTDC to the left of TDC (0) and 4 ATDC to the right of TDC.
The "inner" (upward pointing as viewed in your photo) points are at TDC (0), 6 and 10 BTDC.
Left and right are as viewed in your photo.
Old 05-28-2010, 01:04 PM
MANY, MANY Thanks to all you guys (again).
Timing tab help chipflyer Engine 1 02-14-2010 11:15 AM
Does anyone make a 12:00 timing tab for SBC TNshadetree Engine 7 02-04-2010 10:44 PM
Chevy 383 Stroker timing Hotrodder78 Engine 4 03-16-2009 12:15 AM
need help timing my 96 chevy vortec 305 V8 jw4413nv Engine 4 01-12-2008 10:49 PM
Timing Specs for chevy 350 engine 68_Convertible Engine 3 11-25-2002 06:51 PM
