Chevy tortion bar to spring swap question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2011, 10:16 PM
Gents,
So ive decided to put my 62 GMC half tone on air. The back is complete with bags, mounts and all the good stuff. Now for the front ive taken the tortion bars out and noticed with the 3 bolt lower ball joint its difficult to mount a bag, due to the center bolt. Im intersted in swapping front clips or arms, just not sure what fits. Any suggestions are welcome!
Old 12-20-2011, 03:44 AM
Wiki Edits: 31
The common swap for those is the newer clip. '64 had coils and swap. I think you could do '66-'72 easily also
Old 12-20-2011, 06:28 AM
The entire front crossmeber and front suspension unbolts from the frame, the later suspension and crossmember bolts in. Lot of stuff available to lower the
truck available, ie lower spindles, air suspension etc. Easy way to get disc brakes
also.
Yet another Chevy engine swap question. Quikvmax Engine 10 10-30-2011 09:20 AM
Spring height vs. Spring rate question oldschool101 Suspension - Brakes - Steering 12 06-28-2011 10:06 PM
Small block chevy swap question Leaky Pipes Engine 4 07-18-2010 06:00 PM
Chevy 350 engine swap – motor mount question 78transam Engine 4 06-04-2007 05:57 PM
bucket T single tortion nota57 Suspension - Brakes - Steering 11 12-21-2005 07:41 AM
